Upgrade install from EE2 to EE3?
leeaston's avatar
leeaston
9 years ago
leeaston's avatar leeaston
Do I need to have the latest version of EE2 installed before upgrading to EE3? Thank you!
MDB's avatar
MDB
9 years ago
MDB's avatar MDB
No where in the install instructions does it say you must be running the latest version of 2.x before upgrading to v3. https://docs.expressionengine.com/latest/installation/upgrade_from_2.x.html
leeaston's avatar
leeaston
9 years ago
From EE officially: For the best upgrade results we do recommend having at least 2.10.1 installed before moving to version 3.
TJ Draper's avatar
TJ Draper
9 years ago
TJ Draper's avatar TJ Draper
In my opinion (and past experience), the more incremental you can keep things the better.
That said, EE 3’s installer/updater is very much more robust and trouble free than EE 2’s. EE 2 made great strides in the later days (EE 2.7 plus updates were usually smooth sailing), but I have yet to encounter a failure of the EE 3 installer to do what it is supposed to do.
But why tempt fate? I would update EE 2 to the latest before the major update to EE 3.
leeaston's avatar
leeaston
9 years ago
Thanks for the reply. I’ve updated to the latest EE2 and am now waiting for the next release of EE3 before I upgrade.
