Output dynamic grid row from a related entry
Tom_Watney's avatar
Tom_Watney
9 years ago
Tom_Watney's avatar Tom_Watney
I’m looking to pull in a specific grid row from a related entry, whereby the row is specified by a field on the parent entry:
Parent entry
 Relationship
 Custom_Field
Child entry
 grid_field
  Row 1
  Row 2
  Row 3
I’ve been trying to make this work with row_id without success.
{exp:channel:entries channel="channel_name"}
{preload_replace:set_row_id="
{if Custom_Field == "One"}1
{if:else Custom_Field == "Two"}2
 {relationship:grid_field row_id="{set_row_id}"}
  {relationship:grid_field:field}
 {/relationship:grid_field}
I think it is because it is not possible to pull in dynamic parameters because of the parse order.
I have tried using basic PHP and embed without any luck.
How else could I achieve this goal?
v:2.11.2
Rob Allen's avatar
Rob Allen
9 years ago
Rob Allen's avatar Rob Allen
I’m not sure that preload_replace will work inside an entries tag.
Have you tried hard coding the row ID to see if that works:
    {relationship:grid_field row_id="1"}
Tom_Watney's avatar
Tom_Watney
9 years ago
Hi Rob,
Thank you for your reply. Hardcoding the row_id is fine and pulls in the right data. My goal was to make this dynamic so the row_id is set by a field on an entry.
Though not ideal, I have found a workaround which use {segment_id} which does render within the channel tag parameters as it gets parses sooner.
Rob Allen's avatar
Rob Allen
9 years ago
Yep segment ID will work, you could also use real numbers instead of One, Two etc. in your custom field
Custom text field, ie my_number_field, and populate with a real number like, 1,2,3 etc then call the field value into the relationship tag:
 {relationship:grid_field row_id="{my_number_field}"}
That should work, if all else fails you could put the relationships tag into an embed and pass the number through that way.
