How to retrieve the current entry_id via DB class or any other method within PHP
umbrellatech's avatar
umbrellatech
9 years ago
umbrellatech's avatar umbrellatech
Can anyone help me figure out how do I get the current entry_id via php?
I’m trying to update an entry while viewing it, (so the update will take place before viewing it, i’ll be using the channel api to update the entry but need the entry id,
is there an easier way to get it somehow ?
thank you
Ingmar's avatar
9 years ago
Ingmar's avatar Ingmar
The Channel Entries API doesn’t do the trick?
umbrellatech
9 years ago
The Channel API requires an entry id for all methods, can you post an example of how would i go about updating the current entry?
Ingmar's avatar
9 years ago
Take a look at the Template Class, then.
