[3.4.0 DP] Toggle fieldtype bug in Grid
Developer Preview
Derek Hogue's avatar
Derek Hogue
9 years ago
Derek Hogue's avatar Derek Hogue
When saving a Toggle field in the a Grid field, I’m getting this error:
Undefined index: field_default_value ee/EllisLab/Addons/toggle/ft.toggle.php, line 224
field_default_value is still saved correctly though.
Kevin Cupp's avatar
Kevin Cupp
9 years ago
I’m unable to reproduce this one, and we have automated tests making sure that field saves correctly inside Grid. Any add-ons installed? Or any more specific steps to reproduce?
Derek Hogue
9 years ago
Going through the steps again I’m finding that it only triggers when saving an existing Grid field which already had the Toggle column. It saves fine when you first add the new Toggle column to a Grid.
I do have add-ons installed, but I just tested this on two separate installs of 3.4.0, with different sets of add-ons installed.
Kevin Cupp's avatar
Kevin Cupp
9 years ago
Ah yes I see what’s happening now. It’s not a fatal PHP error, just a notice, so it was hidden by the redirect. I think it’s been that way for a while, but doesn’t look like it’s made anything functionally broken. Curious, how did you come across this? Did you happen to halt execution before it could redirect?
Derek Hogue
9 years ago
Not that I’m aware of - this is on two separate local installs, and I haven’t altered any core files.
It looks like it’s actually the EE_Exceptions::show_php_error() method that’s halting execution after this notice is thrown.
Kevin Cupp's avatar
Kevin Cupp
9 years ago
Maybe your error reporting levels are set differently, curious how this hasn’t come up before. Either way, it should be fixed in the next build. Thanks!
