A System Configuration Override variable or CP setting to set the Reply-to: header for the Webmaster email would be very useful.
There are currently System Configuration Overrides for:
webmaster_email
webmaster_name
You could add
webmaster_reply
allowing the Reply-to: header to be set to a different address than the From: header for the webmaster address set in the control panel.
Great suggestion! Adding a webmaster_reply configuration option would definitely be a valuable enhancement for managing email responses more effectively. Currently, having the webmaster_email and webmaster_name settings is helpful, but a dedicated setting for the Reply-to: header would offer more flexibility.
In the meantime, if you’re comfortable with custom code, you might consider creating a small extension or plugin to handle this. It could allow you to specify a different Reply-to: address for the webmaster emails without altering the core configuration settings.
I’ll upvote your idea and hope it gets some traction. It would definitely streamline communication and improve email handling for many of us! Cheers, geometry dash
