Grid Field Column Width
premier's avatar
premier
10 years ago
premier's avatar premier
Hi
This maybe be a stupid question but i have create a grid field for my channel
There are 8 columns
I have added 100 rows
My issue is that i can only see 4 columns on my page at at time
So if i need to edit the 8th column on row 10 i have to scroll the whole way down to the bottom of the page then scroll to the right and then back up again
I have tried to set the column widths when creating the field like EE 2 but it ignores this value
On EE2 you could set widths as a percentage
Am i missing something?
Or is this the way it will work?
FountainInternet's avatar
FountainInternet
10 years ago
FountainInternet's avatar FountainInternet
You might find this thread useful.
premier's avatar
premier
10 years ago
Thanks Simon
So is this a bug and will it be fixed in a future release?
FountainInternet
10 years ago
I see you’ve replied to the bug report, so EllisLab would need to answer that one.
premier's avatar
premier
10 years ago
Thanks Simon
premier's avatar
premier
10 years ago
Hi Simon
I am using your pluggin it. It works great
One thing these seems to be a bug
Missing argument 1 for Dn_control_panel_css_js_ext::cp_js_end()
user/addons/dn_control_panel_css_js/ext.dn_control_panel_css_js.php, line 185
Could you tell me how to fix this please?
FountainInternet
10 years ago
I’ve fixed that problem and uploaded a new version (1.0.1) of the extension.
premier's avatar
premier
10 years ago
great thanks
