"Enable Debugging" glitchy/not working in secondary sites in Multisite Manager?
News and General
JohnChristianJr's avatar
JohnChristianJr
10 years ago
JohnChristianJr's avatar JohnChristianJr
Hey, folks!
So, I only can test this on my WAMP at this point, but I’m working on a secondary site in my Multisite Manager (EE 3.2.0).
When “Enable Debugging” is on, the benchmark data, etc. does not appear at the bottom of the pages on the secondary site (and yes, I enabled it on the actual secondary site’s “Debugging & Output” settings!). I didn’t have a problem with it on the primary site.
ALSO, though, it seems like when it was turned on, it was making things “glitchy” –for example, after I would make a change on a channel entry, the control panel would be fine, but when I’d refresh the actual site page (even the index page), the page wouldn’t be found in IE 11 -I’d get a “page not found” error (but it didn’t do this in Chrome –weird!). The page would only come up in IE 11 after I would use ccleaner (which would, of course, erase the temp folder, etc).
So, I know that second part is kind of odd, but they do seem to be linked. When I switch “Enable Debugging” to “disable”, I don’t get any of those problems at all (and like I said, I didn’t get any of those problems on the primary site!).
The first part definitely isn’t working though –I don’t get any benchmark data on the second site (in any browser) except on the control panel. So, please let me know if these problems are my problems alone! 😊
Best regards, John Christian
