Create Member Field
andrew001's avatar
andrew001
about 10 years ago
andrew001's avatar andrew001
Currently, in EE 2, Create Member Field is limited to 3 options:
  • text input
    • text area
  • select list
Is there a plugin to extent this? Ive searched devot ee but didnt come up with anything.
Mainly I am looking for a radio select,
File upload would be nice too.
Rob Allen's avatar
Rob Allen
about 10 years ago
Rob Allen's avatar Rob Allen
Not natively and I’ve not seen any 3rd party addons that do. However a Select field does the same job as a bunch of radio fields?
If you need other fieldtypes then one solution is to use http://ee-zoo.com/add-ons/visitor/ which uses channel entries and custom fields to hold member info.
For file uploads f you’re not using them you may be able adapt either avatar, photo or signature photo fields?
andrew001's avatar
andrew001
about 10 years ago
Actually, I might have figured this out.
The issue at hand is this:
I am using expresso store, and the client has a specific form that must be filled out before the purchase can be made.
I’ve beat my head up against a wall trying to integrate 2 forms (freeform pro and expresso store) and be able to carry over this data into the order from.
Then i discovered the custom member field, which i can assign in the expresso order fields… it seems like I can use any form element i want, because all I need to really do is populate that custom field.
So far, so good.
