Entries Not Saving
paultz's avatar
paultz
10 years ago
paultz's avatar paultz
I am having an issue when Saving Channel Entries! i cannot save and the content_publish page doesn’t giving me any errors, and i firefox it keeps rotating and nothing happens, his issue happens in one internet connection while it save normal in another internet connection… i am using ee 2.10.2
Seth Barber's avatar
Seth Barber
10 years ago
Seth Barber's avatar Seth Barber
To clarify: you have one ExpressionEngine site, running 2.10.2; when using FireFox to save a Channel entry when you are at Location A everything works as normal, but when you are at Location B when submitting the form FireFox reports it is working and/or waiting for a response but never finishes. Is this correct?
paultz's avatar
paultz
10 years ago
Yes, that’s correct! Firefox is the browser i am using and on location B i cannot save channel entry and browers keeps on rotating .. and sending never finishes saving, and cannot see any error.
Seth Barber
10 years ago
Do you know if Location B happens to be behind a firewall or proxy or a network security device? It sounds as if POSTing data might be filtered at the network level.
paultz's avatar
paultz
10 years ago
I am not sure if B happens to be behind a firewall or proxy or a network security device?
Attached find screen shot of IP Details when i am station B, and I suspect also that B might have some sort of security device or firewall, if this is the case how can work around this?
paultz's avatar
paultz
10 years ago
Any solution for this? please help
Seth Barber
10 years ago
Have you tried using a VPN service like TunnelBear or Cloak? They both offer a trial or free plan to see if that will make a difference for you while at Location B.
jimmykim's avatar
jimmykim
10 years ago
jimmykim's avatar jimmykim
i’m having the exact issue as paultz. Any workaround for it yet???
Seth Barber
10 years ago
Hi jimmykim,
Have you tried using a VPN service?
paultz's avatar
paultz
10 years ago
Thankx Seith!, Hola Firefox Addon (VPN) - https://hola.org/firefox seen to work also! i had install this on my firefox browser and now on this connection B its saving the posts now, i thought there was another way on ee settings itself.
