ee 3.2.0 DP 1/2, upload directories never show up.
Developer Preview
Greg Ferrell's avatar
Greg Ferrell
10 years ago
Greg Ferrell's avatar Greg Ferrell
In two different installs on 2 completely different machines, no matter what i do i cannot get upload directories to show up after i create them nor can I see the built in ones or directories from an EE 2.x -> 3.x upgrade.
This was an issue in DP 1 as well as DP 2.
Greg Ferrell
10 years ago
The directories exist and are writeable and they are creating in the DB properly
Kevin Cupp's avatar
Kevin Cupp
10 years ago
Pretty odd, not reproducing on my end. Can you show us your module_id column in that table? That should be the only filtering we’re doing, aside from site_id.
kmartens's avatar
kmartens
10 years ago
kmartens's avatar kmartens
Here’s the module_id column 😊
Kevin Cupp's avatar
Kevin Cupp
10 years ago
Interesting, can you tell us the column settings for that column? It should be INT, NOT NULL with a DEFAULT of 0, meaning you shouldn’t have those blank cells there.
