Snippet return whitespace issue
hbsinternet's avatar
hbsinternet
10 years ago
hbsinternet's avatar hbsinternet
I have created a snippet name “abc” and added the below code:
{exp:member:custom_profile_data}
{exp:query sql="SELECT md.m_field_id_1 AS custom_field FROM exp_member_data AS md WHERE md.member_id = '{member_id}'" }{custom_field}{/exp:query}
{/exp:member:custom_profile_data}
When we are accessing this snippet “abc” in tempalte file it returns the value with both side whitespace.
Please check and advise
Kevin Cupp's avatar
Kevin Cupp
10 years ago
Have you tried putting the template contents all on one line? That might get rid of the linebreak whitespace, if that’s what you’re seeing.
hbsinternet
10 years ago
Yes, we had already did but found the same result with linebreak whitespace. Please check and advise
Kevin Cupp's avatar
Kevin Cupp
10 years ago
I’m not reproducing. When I format the snippet like this:
{exp:member:custom_profile_data}{exp:query sql="SELECT md.m_field_id_1 AS custom_field FROM exp_member_data AS md WHERE md.member_id = '{member_id}'" }{custom_field}{/exp:query}{/exp:member:custom_profile_data}
And then render it in a template like this:
test{test_snippet}test
There is no whitespace on either side of the snippet.
hbsinternet
10 years ago
Thanks Kevin, Now it is fixed. We have seen lots of spaces or newline in snippet editors. We have removed it and added the code all on one line.
I was facing another issue to snippet if condition
My snippet “test_snippet” return to 10
If I use below code in “_header” template then it is not checking conditional
if{test_snippet == '10'} {/if}
We have parse it in below way then it works
{embed="ssi/_header" snippet_parse="{test_snippet}"}
Now in header template we have applied below code
if{snippet_parse == '10'} {/if}
then it is working
Kevin Cupp's avatar
Kevin Cupp
10 years ago
That’s not valid EE code, the if should be inside the braces. Even then, try this instead:
<pre><code>{if '{test_snippet}’ == ‘10’} {/if}
hbsinternet
10 years ago
Hi Kevin
We have found following recommend, not wrapping variables in braces ({}) for example, do this:
{if my_snippet == "hello world"}
instead of these:
{if {my_snippet} == "hello world"}
{if "{my_snippet}" == "hello world"}
EE refrence url is https://docs.expressionengine.com/latest/templates/conditionals.html
Please check
Kevin Cupp's avatar
Kevin Cupp
10 years ago
Yes that’s the recommendation but it does not seem to be working in this instance. There are some cases where it still doesn’t quite work to leave out the braces. But yes always try to leave them out first, it should work most of the time.
hbsinternet
10 years ago
Thanks Kevin
