Ability to delete channels from search results
Feature Requests
Frog's avatar
Frog
10 years ago
Frog's avatar Frog
I’m working on a site with lots of channels. To navigate these I tend to use the search feature within the channels page. But when I view the search results I don’t see the usual check box to the right allowing me to select and remove channels. Can this be added please?
Kevin Cupp's avatar
Kevin Cupp
10 years ago
You’re on the Edit Channel Entries page, correct? I’ve just searched using the box in the upper right and the results screen has checkboxes to delete entries with. Can you post a screenshot of what you’re setting?
Frog's avatar
Frog
10 years ago
Frog's avatar Frog
Screen shot attached. No check boxes visible.
FYI I’m running 3.1.2 at present but intend upgrading to 3.1.4 imminently.
Kevin Cupp's avatar
Kevin Cupp
10 years ago
Oh sorry I thought you meant the channel entries search for some reason. Yes, those checkboxes are missing. We can look into adding those. Thanks!
Frog's avatar
Frog
10 years ago
Frog's avatar Frog
Thanks Kevin, that would be great.
