Errors in codeigniter-restserver library
mstdmstd's avatar
mstdmstd
10 years ago
mstdmstd's avatar mstdmstd
Hello, I want to use restful in my ci 3.03 application: 1) I found this link. It has interface methods I need. 2) I downloaded codeigniter-restserver-master.zip file and copied Format.php and REST_Controller.php(@version 3.0.0) files into /application/libraries/REST directory 3) I created control application/controllers/api/Users.php :
<?php
require_once("application/libraries/REST/REST_Controller.php");
require_once("application/libraries/REST/Format.php");
class Users extends REST_Controller
    //protected $rest_format = 'json';
    function users_get()
        //$users = $this->user_model->get_all();
        $filter_username= $this->get('filter_username');
        $filter_user_group= $this->get('filter_user_group');
        $filter_active= $this->get('filter_active');
        $sort= $this->get('sort');
        $sort_direction= $this->get('sort_direction');
        $users_list = $this->muser->getUsersList(false, '', $filter_username, $filter_user_group, $filter_active, $sort, $sort_direction, ''); // that is just ref tomy model
        echo '<pre>'.count($users_list).'::$users_lists::'.print_r($users_list,true).'</pre>
<p>’;</p>
<pre><code>    if($users_list)
        $this->response($users, 200);
    else
        $this->response(NULL, 404);
}</code></pre>
AND RUNNING URL http://local-ci3.com/api/users I got many errors:
A PHP Error was encountered
Severity: Notice
Message: Undefined property: Users::$format
Filename: REST/REST_Controller.php
Line Number: 734
Backtrace:
File: /mnt/diskD_Work/wwwroot/ci3/application/libraries/REST/REST_Controller.php
Line: 734
Function: _error_handler
Line: 649
Function: response
File: /mnt/diskD_Work/wwwroot/ci3/index.php
Line: 292
Function: require_once
Severity: Notice
Line Number: 752
Backtrace:
Line: 752
Line: 649
Function: response
Line: 292
Actually I wanted to get some workable library to help me with REST api creation. I think that is preferable way istead of making from zero. But is this library not workable or does it needs for some fixing? Sorry, what I missed is if this library only for ci 2?
Can you, please, to tell me advice some codeigniter 3 REST api workable library with similar interface like library above?
TJ Draper's avatar
TJ Draper
10 years ago
TJ Draper's avatar TJ Draper
Hi mstdmstd,
Others here are welcome to help you out if they would like, but you’ll probably have much better luck in the CodeIgniter forums. This is the ExpressionEngine forums and while CodeIgniter came out of EE and there’s still al lot of recognizable CodeIgniter in EE, EllisLab decided to sell it and focus solely on EE. So CodeIgniter is no longer an EllisLab product.
Here are the new official CodeIgniter forums:
https://www.codeigniter.com/community
I hope you find the answers you need. Good luck!
