EE2: Saving Templates only directs me to homepage
fx-park's avatar
fx-park
10 years ago
fx-park's avatar fx-park
Hey guys,
I’m currently using EE 2.5.2, and I just had an issue come up recently. Every time I try to edit any of my templates with any notion of JS, JQuery or [removed] code and try to save my changes, it just redirects me to my homepage. The url shows that it’s supposed to go somewhere else, but it doesn’t even redirect me to the admin side.
If anybody has a solution to this issue, I would greatly appreciate it. Thanks!
Derek Jones's avatar
Derek Jones
10 years ago
Sounds like you have some server filtering going on that is rejecting your input, perhaps mod_security; I’d check your error logs or check with your host.
