Question about cache Refresh Interval
restos's avatar
restos
10 years ago
restos's avatar restos
I need some advice with refresh interval. If i don’t write any interval, how cache are refreshed?
Thanks.
Rob Allen's avatar
Rob Allen
10 years ago
Rob Allen's avatar Rob Allen
I rarely use those but I reckon you should always use both parameters
cache="yes" refresh="60"
I’m not sure but I’d guess if you didn’t set a refresh value the caching may not actually happen… I could be wrong though…
Derek Jones's avatar
Derek Jones
10 years ago
If you are meaning on tags as Rob is indicating, then he is correct, if you do not specify the refresh value, no caching will take place. Or more specifically, the refresh will be zero seconds.
restos's avatar
restos
10 years ago
Thank you.
