Upgrade Instructions
Jose B's avatar
Jose B
10 years ago
Jose B's avatar Jose B
Where are the upgrade instructions/documentation for upgrades from 2.7 to 2.10.1? I know you want people to upgrade to 3.0, but deleting previous upgrade instructions is not good.
uwpathology's avatar
uwpathology
10 years ago
uwpathology's avatar uwpathology
Hi, You can find the upgrade instructions in the 2.x User Guide, which you can download here: https://ellislab.com/expressionengine/user-guide/ (Select from the upper right drop down menu)
Hope that helps.
Jose B's avatar
Jose B
10 years ago
uwpathology, link you provided did not have instructions for upgrading/updating from 2.7 to 2.10.0. All the instructions posted on that page are for upgrading to 3.0. Which I am not trying to do at this point.
Jeremy S.'s avatar
Jeremy S.
10 years ago
Jeremy S.'s avatar Jeremy S.
Here you go: http://ee2docs.com/installation/update.html
