EE 3.1 DP: When a model is given a ->fields() directive it only retrieves one result.
Developer Preview
Greg Ferrell's avatar
Greg Ferrell
10 years ago
Greg Ferrell's avatar Greg Ferrell
In EE 3.0, if you used something like this:
$result = ee('Model')->get('ModelName')->fields('myColumn')->all();
You would get all results with just the myColumn field set.
In ee 3.1 if you use ->fields() on a model it will only return one result no matter what limit you set or how else you retrieve the data.
Removing ->fields() and leaving every other filter or limit directive on a model gets the desired results.
Kevin Cupp's avatar
Kevin Cupp
10 years ago
Hmm I’m unable to reproduce, Greg. We’re using fields() a lot, too, so I suspect it would have broken a lot if that’s all it took to reproduce. Are you seeing this with one of our native models?
Greg Ferrell
10 years ago
We are using them with multiple addons, multiple devs and multiple EE 3.1 installs.
It is our models, but we are using the model interface laid out in the docs and it worked in EE 3.0:
class Group extends Model
 protected static $_primary_key = 'tag_group_id';
 protected static $_table_name = 'tag_groups';
 protected $tag_group_id;
 protected $tag_group_name;
 protected $tag_group_short_name;
//END Group
Kevin Cupp's avatar
Kevin Cupp
10 years ago
I’m not sure what to recommend, I can’t reproduce with models in an add-on either. Does it still do it if you try to access something like ChannelEntry?
Greg Ferrell
10 years ago
I did it using the member model (since it extends Model and ChannelEntry does not) and the bug persists. It’s only when its not the primary key in the ->fields()
This produces 1 result:
ee('Model')->get('Member')->fields('screen_name')->all()->getDictionary('screen_name', 'screen_name');
This produces many:
ee('Model')->get('Member')->all()->getDictionary('screen_name', 'screen_name');
Greg Ferrell
10 years ago
I should add for whatever reason, if the ->fields() contains the primary key, it works as expected.
Kevin Cupp's avatar
Kevin Cupp
10 years ago
Thanks, Greg! That’s the ticket. I’ve tracked down the problem and put in a fix, should be working correctly in the next build.
Greg Ferrell
10 years ago
Great news. Thanks!
