3.0.1 to 3.1.0 update does not rename installer directory
Developer Preview
TJ Draper's avatar
TJ Draper
10 years ago
TJ Draper's avatar TJ Draper
When updating from 3.0.1 to 3.1.0, the installer directory is not renamed and login to the CP is prevented until manual deletion of directory. Based on Wes’ talk at EE Conf and previous behavior I assume this is a bug.
Wes Baker's avatar
Wes Baker
10 years ago
Wes Baker's avatar Wes Baker
I don’t think anything changed there. Were there any permissions issues?
Derek Hogue's avatar
Derek Hogue
10 years ago
Derek Hogue's avatar Derek Hogue
Just found the same thing here, running locally on MAMP.
Bjørn Børresen's avatar
Bjørn Børresen
10 years ago
Bjørn Børresen's avatar Bjørn Børresen
Also, I think it would make sense to list the actual directory that needs to be removed.
Wes Baker's avatar
Wes Baker
10 years ago
I’m guessing this is due to the mailing list export which is likely still in your cache. Look at system/ee/installer/controllers/wizard.php and edit line 2394 so it looks like this:
if (version_compare($this->version, '3.0.0', '=')
 && file_exists(SYSPATH.'user/cache/mailing_list.zip'))
Let me know if that fixes the problem for you.
