I found this error because i named a model’s class differently than its filename on accident.
If you have a model named Test.php and inside there is no class Test {} and you call class_exists('\Namespace\Model\Test') more than one time, the autoloader will attempt to load the file a second time, throwing a duplicate class error.
To fix the issue i changed:
/EllisLab/ExpressionEngine/Core/Autoloader.php:100
if (file_exists($class_path))
require $class_path;
return;
}to:
require_once $class_path;
return;
}Packet Tide owns and develops ExpressionEngine. © Packet Tide, All Rights Reserved.
