EE3 DP3: Changing formatting for textarea field will always select 'None'
Developer Preview
Low's avatar
Low
10 years ago
Low's avatar Low
I tried to change the Text Formatting setting for an existing Textarea field in the field’s settings. For example, from
to xhtml. After saving, the option is set to ‘None’, and stays there, even after saving again. The value is updated correctly in the DB, tho.
Seth Barber's avatar
Seth Barber
10 years ago
Seth Barber's avatar Seth Barber
Thanks for catching that Low! I’ve got it fixed and it will be in the next build.
