Pagination on a series landing page
rjionline's avatar
rjionline
10 years ago
rjionline's avatar rjionline
On the new website we’re developing, we’ve created what we’re calling series — a series of entries collected together under a common banner, like a newspaper column.
Series are a separate channel from stories. A series landing page is just supposed to display a list of teasers that link to the stories that fall within it.
Unfortunately, for some reason we can’t get pagination to work on the series landing pages. I was hoping someone here might have some suggestions for us.
Here’s the template for the series.
{html_head}
 <title>
 Post Series | RJI
 </title>
 {head_content}
{html_head_end}
{embed="main/_navbar"}
<ol class="breadcrumb">
 <li><a href="http://{site_url}">Home</a></li>
 <li><a href="http://{path=stories/index}">Stories</a></li>
 <li class="active">Series</li>
</ol>
<div id="main-section" class="container">
<div class="row">
 <div class="col-md-8 col-sm-12">
  <div class="page-header">
   <h2>Post Series</h2>
  </div>
   <div class="card-bg">
  <ul id="recent-posts" class="media-list">
    {exp:channel:entries channel="series" disable="categories|member_data|pagination"}
     <li class="media card">
      <a href="http://{post_path}class=pull-left">_       {!-- If there is a news image, use that, else maybe it's an event so if there is an event image use that, else there is no given image, use default image --}_       {if series_image}_        {series_image}_       {url:rect}_      {/series_image}_       {if:elseif series_banner}_      {series_banner}_       {url:rect}_      {/series_banner}_       {if:else}_         {site_url}/images/posts/rji-post.jpg_       {/if}_      </a>
      <div class="media-body">
       <h4 class="media-heading"><a href="http://{post_path}">{title}</a>
<span class="small capitalize">{entry_date format="%F %j, %Y"}</span></h4>
       {exp:trunchtml chars="256" exact="yes" ending="..."}{series_description}{/exp:trunchtml}
      </div>
     </li>
  </ul>
  </div>
    </div>
    <div id="sidebar" class="col-md-4 hidden-sm hidden-xs">
    {embed="main/_sidebar" recent="YES" events="YES" related="NO" topics="NO"}
    </div>
</div>
</div>
{page_end}
Thanks.
L.
rjionline's avatar
rjionline
10 years ago
Just a note: I see that pagination has been disabled in the template. My assistant did that while trying to make the template work. The problem is that trying to move to another page of teasers displays a 404 error.
L.
Boyink!'s avatar
Boyink!
10 years ago
Boyink!'s avatar Boyink!
I don’t see pagination code?
rjionline's avatar
rjionline
10 years ago
Whoops. I forgot the pagination code was in a separate snippet.
{!-- Using custom pagination so Bootstrap CSS can work (need classes .pagination .page-first .page-last) --}
{paginate}
  {pagination_links}
 <ul class="pager">
   {previous_page}
    <li class="previous"><a href="http://{pagination_url}#recent-posts">← Newer</a></li>
   {/previous_page}
   {next_page}
  <li class="next"><a href="http://{pagination_url}#recent-posts">Older →</a></li>
   {/next_page}
 </ul>
  {/pagination_links}
{/paginate}
Boyink!'s avatar
Boyink!
10 years ago
So what URLs are being generated? And do you have .htaccess or anything else that would affect URLs?
