Redirect without login
Nacho_EE's avatar
Nacho_EE
10 years ago
Nacho_EE's avatar Nacho_EE
Hi!
Last week un updating EE 2.5.5 to 2.9.2 and then update some modules website runs fine but I discovered that if I login in CP, the REDIRECT label works perfectly but if I visit the front-end without user access or no access to CP redirection fails and displays a blank page.
Someone can tell me any idea where is the problem?
I’ve looked at a lot of sites do not find a solution.
PS: I use the “Channel files” module and have found that if the user logged on to the CP, downloading and running, but the user does not have access to CP or a guest does not work and I think it is the same problem
Nacho_EE's avatar
Nacho_EE
10 years ago
It seems I found the problem. 😊
The website returned an error 503 and I was because the web work properly labeled option was not online system. :roll:
I do not understand that worked for all users if it was off 🐛
