Network Solutions server path
fensterbaby's avatar
fensterbaby
about 11 years ago
fensterbaby's avatar fensterbaby
Network Solutions support is useless.
I need to know the server path format.
for example the third party directory should be something like this…
/www/username/htdocs/third_party/
but am not sure what preceeds /htdocs/
Anyone hosting on Network Solutions that can help out?
groupe_edh's avatar
groupe_edh
about 11 years ago
groupe_edh's avatar groupe_edh
You can determine the path while you are logged in via FTP (some programs will tell you this) or while using a File Manager tool in your Control or Administrative Panel (if your host provides one for you).
You can create a pathinfo.php file. Open a plain text editor, and paste in the following:
[code]<?php echo $_SERVER["SCRIPT_FILENAME"]; ?>[/code]
Save the text file as pathinfo.php. Upload the file to your server.
Now, type the URL to the file you just uploaded into your browser to view the full server path to that file.
If none of these solutions work, you may need to ask your host for the full server path for your system and account.
fensterbaby
about 11 years ago
Thanks. I had a info.php file that, among other things, returned the path I needed.
