Unknown column 'order' in 'order clause'
DoctorLove's avatar
DoctorLove
11 years ago
DoctorLove's avatar DoctorLove
Hello,
we’ve recently updated a website to EE 2.9.3, but when linking to an non existent page, it should redirect to a 404 page. Instead, we get this:
Error Number: 1054
SELECT `route_parsed`, `template_name`, `group_name` FROM (`exp_templates`) JOIN `exp_template_routes` ON `exp_templates`.`template_id` = `exp_template_routes`.`template_id` JOIN `exp_template_groups` ON `exp_templates`.`group_id` = `exp_template_groups`.`group_id` WHERE `route_parsed` is not null AND `exp_templates`.`site_id` = '1' ORDER BY `order`, `group_name`, `template_name` ASC
Filename: libraries/Template_router.php
Line Number: 83
Now, I checked the database and there is indeed no ‘order’ in exp_templates. To know what type this field should be, I did a clean install elsewhere on 2.9.3 and noticed this field isn’t there at all. The request to it though, in Template_router.php, is.
Any ideas?
airways's avatar
airways
11 years ago
airways's avatar airways
The order column is on the template_routes table, which is joined to in that query.
If you’re upgrading then maybe this table is empty? That would certainly count as a bug.
Try going to Design > Templates > Template Route Manager and click the “Update” button at the bottom. This should update the contents of the template_routes table to have values for your templates.
If this doesn’t work, you may want to submit a bug to the bug tracker, which you may want to do anyway.
DoctorLove's avatar
DoctorLove
11 years ago
Thanks for your response.
The table itself is not empty, but the order field doesn’t exist in it. I tried to do as you said (update the template route manager), but when I go to the Template Route Manager page, it gets me this error:
Error Number: 1054
Line Number: 83
So yeah, pretty much the same error 😊 I could just add a ‘order’ field to this table myself, using Sequel Pro, but I need to know the correct type of this field.
