Copy and Paste into Grid does not work in MS Internet Explorer 11
mgx's avatar
mgx
11 years ago
mgx's avatar mgx
EE version 2.9.2 MS Internet Explorer 11.0.9
Serious bug with ‘Grid’ in MS IE 11 - in that you cannot copy & paste text into a Textarea (rich text) field.
Can you please update on when this will be fixed?
Giraffentoast's avatar
Giraffentoast
11 years ago
Giraffentoast's avatar Giraffentoast
You might want to report a bug instead of posting in the Community Support forum. 😉
Also, could it be that this has to do with Rich Text fields, not Grid…? Or does it only work with Rich Text Fields inside Grid?
mgx's avatar
mgx
about 11 years ago
mgx's avatar mgx
You might want to report a bug instead of posting in the Community Support forum. 😉 Also, could it be that this has to do with Rich Text fields, not Grid…? Or does it only work with Rich Text Fields inside Grid?
It has already been submitted as a bug.
And, yes the bug is with all Rich Text Fields.
jamesparvin's avatar
jamesparvin
jamesparvin's avatar jamesparvin
@slither io want rather of making a post in the Community Support section, you might prefer to report a bug.
