Show content parts with status parameter?
Riverboy's avatar
Riverboy
11 years ago
Riverboy's avatar Riverboy
I need a way to show channel:entry content with open vs custom status.
By this I mean: Show basic fields and their content if status is “open” Show ALL fields when status is “custom”.
I tried to use conditional inside of channel:entry loop but that didnt get me anywhere but errors. So seems that using if status=”custom” is not available for to use (bummer)…
How I can hide/show fields on entry page depending on entry status?
Is the only way to make 2 channel:entry looping pairs with other having status set to “open” and putting fields I want to show inside, and then double it and changing status to “custom” and putting all fields inside of that looping pair?
If so, that sucks :(
Am I missing something that can be used to filter content fields with status parameters using only one channel:entry loopin pair?
Riverboy's avatar
Riverboy
11 years ago
Got solved this one. But if someone might have the same issue what I have:
Be sure to use exact word. So this didnt work on my case:
{if status == 'custom'}--content here--{/if}
But this is working
{if status == 'Custom'}--content here--{/if}
In, at least my case and installation, 2 default statuses (open and closed) does not have to start with capital letter, but custom statuses I’ve added, has to start (because when I created those, I typed new status as Custom, not custom) - making things a bit confusing because when using statuses in channel:entry opening tag as a parameter, they does not need to start with capital letter.
