Template views 404
ThePixelPusher's avatar
ThePixelPusher
11 years ago
ThePixelPusher's avatar ThePixelPusher
I’ve been away from ExpressionEngine for a while so maybe I’m out of touch with new developments, but I’ve updated my installation to the latest and things don’t seem to be working.
  1. Under Design > Templates there is a new item called nav_template_route_manager.
Now this looks weird, its underscored for one, but I don’t understand it’s purpose.
  1. I have a template group called Projects and within that template group a template called view. Now under Access I select ‘Select All’ and get this error:
{"error":" Unable to load the requested language file: language\/english\/template_router_lang.php<\/p>"}
I’ve never had that file, so not sure why it’s throwing an error. By that I mean I’ve worked ok on this in the past, but now it’s doing this.
and it also says ‘If you selected ‘no’ in any of the above’ articles/index - and when I try and change it to projects/index and save, it always defaults back to articles/index
Finally, when I click to view the template it gives me the 404 error.
I appreciate this is a lot of stuff here, but I’m kind of hoping it’s all tied into one issue. Any help would be greatly appreciated.
Boyink!'s avatar
Boyink!
11 years ago
Boyink!'s avatar Boyink!
Sounds like your upgrade isn’t complete. I’d try re-uploading all the files.
ThePixelPusher
11 years ago
Yeah giving it another go. Not sure what happened as I followed the instruction closely. Trying again.
ThePixelPusher
11 years ago
Ok, so I re-updated. The earlier errors don’t exist, but I still get a 404 for my views page.
Boyink!'s avatar
Boyink!
11 years ago
Do you have error reporting turned on?
ThePixelPusher
11 years ago
Yes, but I get a Not Found page.
Boyink!'s avatar
Boyink!
11 years ago
Just for that template?
If you copy it to a different group does it load? Or rename it?
ThePixelPusher
11 years ago
All of them. When I go to the root of my site I see the index page fine, when I click the view link in Template Management it goes to 404.
ThePixelPusher
11 years ago
This is the reply I get.
Not Found
The requested URL /projects/view was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
ThePixelPusher
11 years ago
One other thing. I have my templates folder in system/expressionengine/templates
Is that not right?
Boyink!'s avatar
Boyink!
11 years ago
Your templates can be just about anywhere on the server but you have to tell EE where they are stored. It’s in global template prefs.
ThePixelPusher
11 years ago
Yeah I’ve set that ok. I’m at a loss to what’s going wrong.
Boyink!'s avatar
Boyink!
11 years ago
.htaccess?
ThePixelPusher
11 years ago
success!!!
Now all I need now is some plutonium to get the flux capacitor working and a straight road to get up to 88mph. Damn I feel stupid for wasting most of my afternoon on this. Such a rookie mistake.
Thanks Boyink!
Boyink!'s avatar
Boyink!
11 years ago
Ahh..no worries. Sometimes fresh eyes are all that’s needed.
1 2
