Sudden blank page, with deep sql error
Sylvain Hugues-Laclef's avatar
11 years ago
Sylvain Hugues-Laclef's avatar Sylvain Hugues-Laclef
Hi, suddenly got a blank page on www.dev.tv I nor my customer had modified anything. In my templates, I can write static text but each time I write
{exp:channel:entries channel="..." }
tag I got blank page.
Don’t know why but sometimes I got this sql error
Error Number: 2013
Lost connection to MySQL server during query
SELECT `field_id`, `field_type`, `field_fmt`, `field_name`, `site_id`, `field_settings` FROM (`exp_channel_fields`)
Filename: libraries/api/Api_channel_fields.php
Line Number: 150
I would love it simply comes from my host having change PHP config…
Thanks, Sylvain.
Jeremy S.'s avatar
Jeremy S.
11 years ago
Jeremy S.'s avatar Jeremy S.
That error (#2013) likely means you are timing out while trying to complete the MySQL query. It could be a couple things, but it’s likely best to contact your host provider to see if they have changed any default settings or upgraded PHP and maybe reset defaults etc.
