how to check if grid field is empty
captainahab's avatar
captainahab
11 years ago
captainahab's avatar captainahab
I just need to check if one field artist_gallery:image in a grid field is set, if not the markup should not be rendered. This syntax {if "{artist_gallery:total_rows}” > 0} or {if artist_gallery:total_rows > 0} is not working … if there is no image, the markup is rendered.
Any ideas? Thank you!
{if "{artist_gallery:total_rows}" > 0}
 <div id="artistgallery">
  <div class="cycle-slideshow">
   {artist_gallery}
    {artist_gallery:image}
   {/artist_gallery}
  </div>
  <div id="adv-custom-pager" ></div>
  <div class="clb"></div>
 </div>
Riverboy's avatar
Riverboy
11 years ago
Riverboy's avatar Riverboy
I have no idea whats the deal with total codes in your template and how you have built it, but have you tried this:
{artist_gallery}
  </div>
 </div>
 {/artist_gallery}
Havent tried but it should not show anything if there is no image available?
captainahab
11 years ago
That’s the first thing I tried. If no image is present, nothing is present – but if there is more than one image, everything inside {artist_gallery} is rendered for every single image.
Riverboy's avatar
Riverboy
11 years ago
So you want to pull out less markup, and the conditional is working when there is images right?
What about this then, (if your code is working when images available):
   {artist_gallery}
   {/artist_gallery}
  </div>
 </div>
{if:else}
FOO and a BAR :blush:
I have no idea again, does that produce some sort of conflict…
captainahab
11 years ago
Seems the rows of the grid have nothing to do with the objects inside the rows. What ever condition I use, I get strange results – sometimes a second image is rendered outside the gallery container … I’ll try something else. Thank you for your help.
Riverboy's avatar
Riverboy
11 years ago
Yep, sometimes we all need to re-think how-to. Shout out with the results how you finally did it?
