next previous entry filter
macguido's avatar
macguido
11 years ago
macguido's avatar macguido
I have a channel “portfolio” in which there are entries (photo). Each photo has both a category and some tag. I’m using dev demon tagger plugin. No problem in showing a list of photos filtered by either category or tag. The problem comes in the view page of the single entry, when the user navigates through the entries. The next/prev links work well with categories:
{exp:channel:entries channel="portfolio" disable="member_data|pagination" limit ="1"}
...some code here
then outside the channel loop:
{exp:channel:next_entry channel ="portfolio" category="{last_segment_category_id}"}
...some code here
{/exp:channel:next_entry}
But is there a way to show next/prev entry links filtered by tag? Should I use a custom sql query? Or perhaps use a different template page for the tags?
Here is my url structure:
www.example.com/portfolio this shows a list of categories (they are actually galleries of photo divided by category)
The items list has this url structure: www.example.com/portfolio/list/category/category_name and each item links to a list of pictures filtered by “category_name”
www.example.com/portfolio/view/entry_title/category_name
On the view page of the single entry, the tags list link is: www.example.com/portfolio/list/tags/tag_name
This links to a list of pictures filtered by tag. But again, when going from the entries tag list to the view page, I cannot get the next/prev links to work filtered by tags.
Can this be done?
