Radio buttons with comments
bsjosten's avatar
bsjosten
11 years ago
bsjosten's avatar bsjosten
When adding new entries via the CP, I need to create radio button fields with descriptive labels, but store simple integers in the database. How can this be done?
For example, I need a field to specify units. I would like two radio buttons with the labels “metric” and “imperial”, but in the database I want to store either 1 or 2 to remember the selection.
Similar for months of the year, etc.
The reason for this is so that I can display the site in different languages, where things like names of months etc are different.
/Bo
Boyink!'s avatar
Boyink!
11 years ago
Boyink!'s avatar Boyink!
I think you’d need to create a custom field(s), but there are other ways to skin the multi-lingual cat. I’d recommend the Transcribe add-on.
