config.php does not have the correct permissions. BUt IT DOES!
NANB's avatar
NANB
11 years ago
NANB's avatar NANB
I am getting the dreaded - “config.php does not have the correct permissions” error when trying to install EE 2 to newly built LAMP, CENTOS server.
I have scoured the forums and Google and saw others having the same issue. However, I did not find a solution.
My server wizard says all is fine. My mariaDB (MySQL) connects without issue and I have a web DB set up and ready.
I have checked and tripled checked the file permissions. I even downloaded a bash script I found in a previous post which set the correct permissions as well.
Any help is greatly appreciated.
NANB
