Download to Excel or csv solutions
Okapi Creative's avatar
Okapi Creative
11 years ago
Okapi Creative's avatar Okapi Creative
We need to get download functionality where channel entries can be downloaded to an Excel spreadsheet (preferably) or a csv at a push.
Been looking at Export_It and using it which is ok but ran into two problems which apparently are not solvable - at least have never got any results investigating them - so need maybe another solution.
The problems in question were/are:
1) Strange characters in the spreadsheet if the file contains accented foreign characters. I believe integrating PhpExcel with Export_It should fix this but I never got this working and no-one on PhpExcel forums or elsewhere seems to know anything about the error.
2) We need to be able to take data from TWO categories in the download: i.e. category=”1&2” in the parameters. Have not been able to find out if Export_It supports this but it seems not as it doesn’t work.
So we need another solution. Has anyone successfully implemented PhpExcel as a stand-alone in EE? Are there any other modules or solutions you might recommend?
