Extended rights within Wygwam
Caymen14's avatar
Caymen14
11 years ago
Caymen14's avatar Caymen14
Hello,
i’m using the Wygwam Editor. HTML and links are disabled. I would like to enable them for admin users. IS there a way to do that? If not - is there any other editor allowing to set different rights for different roles?
Thanks, Caymen14
Caymen14's avatar
Caymen14
11 years ago
no one?
Jeremy S.'s avatar
Jeremy S.
11 years ago
Jeremy S.'s avatar Jeremy S.
You can customize an editor configuration in Wygwam on a per field basis, but I think only Wyvern allows you to specify based on member group.
https://boldminded.com/add-ons/wyvern
Caymen14's avatar
Caymen14
11 years ago
Thank you!
