Nested Channel Entries Tags
motorstormer's avatar
motorstormer
11 years ago
motorstormer's avatar motorstormer
For some reason I can’t get this to work in EE. It is a channel entries tag nested within another. The syntax appears to be ok.
{exp:channel:entries entry_id="{embed:pageid}" dynamic="no"}
            <div class="subContent">
                {exp:channel:entries channel="examples"}
                    <h3>{example_header}</h3>
                    {example_description}
                    <a href="http://{example_link}">{example_link_text}</a>
            </div>
Boyink!'s avatar
Boyink!
11 years ago
Boyink!'s avatar Boyink!
What are you trying to do?
motorstormer
11 years ago
Nevermind, I just need to use {embed="subTemplate"} to effectively nest channel entries tags. Answered my own question. Thanks.
Boyink!'s avatar
Boyink!
11 years ago
Just keep an eye on how many queries are being generated - there are typically better coding approaches than nested entries loops.
strudel's avatar
strudel
11 years ago
strudel's avatar strudel
Hi, I was wondering what the better coding approaches are?
What I’m trying to accomplish: I’m doing an art gallery site and the front page should have the current exhibition info on it. If there is no current exhibition, a different layout with text/images coming from a different channel should appear. Is there a better way than nesting channel entries than this do you think?
Thanks in advance!
Boyink!'s avatar
Boyink!
11 years ago
Depends on how you know if there is an exhibition or not..but sounds like a great case for some conditionals.
strudel's avatar
strudel
11 years ago
Basically, I’m just using {if no_results} to trigger the alternate front page info, and using an embed so it will work. Does that seem the way to go?
Boyink!'s avatar
Boyink!
11 years ago
Thats the thing with EE…there’s probably 6 ways to go..😉 And anyone who says there is a ‘best practice’ is trying to sell you something.
If it works and the query counts/load times are acceptable then run with it.
strudel's avatar
strudel
11 years ago
Thanks for your (as usual) valuable insight!
