Problems returning object
o_Pi_DC's avatar
o_Pi_DC
11 years ago
o_Pi_DC's avatar o_Pi_DC
Hello people.
Im having troubles returning an array.
I have a controller with this statement
$data['json'] = $this->resource_model->getList($business, $superUser);
The getList method is this one
if ($superUser == 0) {
        $query = $this->db->get_where("resources", array('business_id' => $business));
    else {
        $query = $this->db->get("resources");
    $data = array();
    foreach ($query->result() as $row) {
        $resource = new Resource_model($row->id);
        array_push($data, $resource);
    if (sizeof($data) == 0) {
        return not_found_array();
    else {
        return ok_data_array($data);
And this is ok_data_array() code:
$ret = array(
        "status" => 200,
        "message" => "OK",
        "data" => $data
    return $ret;
Again in the controller, after load data[‘json’], i send the response to a view:
$this->load->view('common/json_response_view', $data);
So debugging i saw that $data variable in getList function has the right content and also in ok_data_array but, in the controller, it has empty value.
What am i doing wrong?
the restultant json is this one:
{ “status”: 200, “message”: “OK”, “data”: [ {}, {} ] }
EDIT: i “solved” it adding the rows to the array beside adding the object. Anyway, i would like to know whats going on there.
