Nested layout inheritance breaking
Developer Preview
johndwells's avatar
johndwells
11 years ago
johndwells's avatar johndwells
Much like the EE docs for templates, I have a template with a layout, and that layout itself has a layout. Yet when I try to run it, I get this message:
Plugin or module tag found before layout declaration. Please move the layout tag to the top of your template.
This setup was working in 2.8.1.
For testing purposes this is the general idea:
{!-- site/page.html --}
{layout="site/_page_layout.html"}
Ohai
{!-- site/_page_layout.html --}
{layout="site/_layout.html"}
Page says {layout:contents}!
{!-- site/_layout.html --}
<blockquote>"{layout:contents}"</blockquote>
Kevin Cupp's avatar
Kevin Cupp
11 years ago
Thanks, John. I ran into this too, I think it happens if your template has no {exp: tags in it. Try this fix and see if it works:
Open system/expressionengine/libraries/Template.php, find this code on line 585:
if ($tag_pos > $first_tag)
And REPLACE it with this:
if ($tag_pos > $first_tag && $first_tag !== FALSE)
Thanks for your reports lately!
johndwells's avatar
johndwells
11 years ago
Thanks Kevin, the code update works. FWIW, there were exp:channel:entries tags in both the parent template, its layout, and the layout’s layout. ¯_(ツ)_/¯
Kevin Cupp's avatar
Kevin Cupp
11 years ago
Glad to hear! I think that makes sense, module tags can be present in parent templates but if any template that contains a {layout=} tag doesn’t have any module tags, that should be what’s triggering the bug.
