how to read csv file saved in webserver using codeigniter.
gglenn12's avatar
gglenn12
12 years ago
gglenn12's avatar gglenn12
good day everyone, I start using codeigniter for 3 weeks. I’m developing a system that save csv file, the problem is i don’t know how to view the file that i save in my web server.
this is how i save/find csv file together with the file name
controller
function SaveOrFind()
  $this->load->helper(array('form', 'url'));
  $this->load->model('dtr_model');
                $this->load->library('csvimport');
  if(isset($_POST["btnSaveAndSubmit"])){
   $config['upload_path'] = './uploads/';
   $config['allowed_types'] = 'csv';
   $this->load->library('upload', $config);
   $this->load->library('form_validation');
   $this->form_validation->set_rules('selTimerecordMonth', 'Month', 'required');
   $this->form_validation->set_rules('selTimerecordPeriod', 'Period','required');
    if ( !$this->upload->do_upload() || $this->form_validation->run() == FALSE)
     $error = array('error' => $this->upload->display_errors());
     $this->load->view('header');
     $this->load->view('dtr_nav');
     $this->load->view('dtr_timerecord_nav');
     $this->load->view('dtr_timerecord_main', $error);
     $this->load->view('footer');
    else
     $image_data = $this->upload->data();
     $insert_data = array(
      'FILENAME' => $image_data["file_name"],
      'MONTH'=>$this->input->post('selTimerecordMonth'),
      'PERIOD'=>$this->input->post('selTimerecordPeriod'));
     $query = $this->db->insert('dtr_timerecord',$insert_data);
     $id = $this->db->insert_id();
     $file_data = $this->upload->data();
              $file_path =  './uploads/'.$file_data['file_name'];
     echo "[removed]alert('Upload Successful: ". $file_data['file_name']."');[removed]";
     $this->timerecord();
    if(isset($_POST["btnFind"])){
     if ($this->form_validation->run() == FALSE)
      $this->load->view('dtr_timerecord_main',array('error'=>''));
     else
      $data=array('result'=>$this->dtr_model->finddtr());
      $this->load->view('success_dtr_find',$data);
model
function FindDtr(){
 $getInfo = "SELECT * FROM dtr_timerecord WHERE MONTH ='".$this->input->post('selTimerecordMonth')."' AND PERIOD ='".$this->input->post('selTimerecordPeriod')."'";
        $getResult = $this->db->query($getInfo);
  return $getResult;
view in viewing csv file
<html>
<head>
</head>
<div id="content">
<?php
echo"<table border='1' >
 <tr>
  <th></th>
  <th>MONTH</th>
  <th>PERIOD</th>
  <th>FILE NAME</th>
  <th>ACTION</th>
 </tr>";
 foreach ($result->result_array() as $row) {
  echo "<tr>";
  echo form_open("dtr/importcsv");
  echo"<td><input type='hidden' name='txtTimeRecordID' value='".$row["TIME_RECORD_ID"]."'></td>".
  "<td align='center'>".$row["MONTH"]."</td>".
  "<td align='center'>".$row["PERIOD"]."</td>".
  "<td align='center'>".$row["FILENAME"]."</td>".
  "<td><input type='submit' value='VIEW'></td>";
  echo form_close();
  "</tr>";
echo "</table>";
echo "
echo anchor('dtr/timerecord', 'BACK');
</div>
</html>
Boyink!'s avatar
Boyink!
12 years ago
Boyink!'s avatar Boyink!
You’ve posted in the ExpressionEngine forum - might want to try the CI forums…;)
