Formatting Being Removed
Stuart's avatar
Stuart
12 years ago
Stuart's avatar Stuart
I have a textarea field that I’ve assigned Auto < br / > as the formatting. This works fine when I display the field through the {exp:channel} tag, but when I grab the field through the {exp:query} tag, the < br / > tags disappear.
I’ve tried changing the formatting to none, updating all entries and then updating them again back to < br / >, it still isn’t working.
Is this normal behavior or am I missing something?
Stuart's avatar
Stuart
12 years ago
I changed the formatting to None. Now instead of just hitting Return to start a new line, I press Shift Return to visibly place a < br > in the text field and create a new line.
Not the solution I was hoping for, but it works.
