Grid Field
Mauricio Dulce's avatar
Mauricio Dulce
12 years ago
Mauricio Dulce's avatar Mauricio Dulce
I have problem, I need not display a grid field in my template when is empy, this is the example, I need this for a secondary menu
Case 1: In this case the field not display, only happen when I use a grid field type, works fine whit others.
{exp:channel:entries channel="channel"  limit="1" disable="member_data|category_fields|pagination" }
 {if "{grid_field}" != ""}
 {value}
Case 2: In this case the field display empy or not.
 {if grid_field != ""}
 {value}
All different types or field types works fine, but not in grid.
Tks
Mauricio Dulce
12 years ago
Ok, this work for me
 {if grid_field:total_rows > 0 != ""}
 {value}
