Redirect after login
holden321's avatar
holden321
12 years ago
holden321's avatar holden321
Hello I want to do redirect a page if a user is not logined or not admin and return to the start page. I can redirect to login page:
ee()->output->set_header("Location: http://example.com/admin.php?S=0&D=cp&C=login&return;=");
But I can’t understand what should I put in “&return;=??????” so that the user return to the start page. I tried
"&return=http://example.com/startpage"
(urlencoded of course) but it doesn’t work (Disallowed key characters) I noticed that EE put there some code like:
&return=Qz1hZG1pbl9jb250ZW50JmFtcDtNPWNoYW5uZWxfbWFuYWdlbWVudA==
So what is the code and how can I encode a link to that code? Thank you!
Aamir.cs's avatar
Aamir.cs
12 years ago
Aamir.cs's avatar Aamir.cs
First of all create a session and set logged in user data like
        [quote]  $this->load->model('membership_model');
$query = $this->membership_model->validate();
if($query) // if the user’s credentials validated… { $data = array( ‘username’ => $this->input->post(‘username’), ‘is_logged_in’ => true ); echo $this->session->set_userdata($data); redirect(‘site/member_profile’);
} else // incorrect username or password { $this->index(); }
after that put these line in the constructor of every controller
if(!is_logged_in()) { redirect(‘login’); // loginis the controller name }
Hope so this will help you.
holden321's avatar
holden321
12 years ago
$this->load->model(‘membership_model’);
Error
Unable to locate the model you have specified: ‘membership_model’
holden321's avatar
holden321
12 years ago
Fatal error: Call to undefined method EE_Session::set_userdata()
holden321's avatar
holden321
12 years ago
OK, that code is base64 encoded string, but not url - it is a special query string like a=1&b=2, so you can’t simply redirect to any page you want.
davidsmith's avatar
davidsmith
12 years ago
davidsmith's avatar davidsmith
Write following code to redirect the page.
header(‘Location: http://www.example.com/’);
