Adding categories to multi edit form
ppm's avatar
ppm
13 years ago
ppm's avatar ppm
Hi
I am looking into the possibility of adding a category select option into the multi edit form for channel entries.
I have looked into the system > expressionengine > views > content > multi_edit.php and was wondering if this would be possible, if so, where would be a good place to start.
Any advice appreciated.
Many thanks
Bhashkar Yadav's avatar
Bhashkar Yadav
13 years ago
Bhashkar Yadav's avatar Bhashkar Yadav
You can select “Add Categories” from the same drop down and can add the categories to the selected entries.
Best Regards,
