Upgrading EE1 Plugin to EE2
Triad's avatar
Triad
13 years ago
Triad's avatar Triad
Hello after lots of research on the internet I have found myself at a loss what to do. Please can anyone help. I am looking at a way of upgrading a EE1 plugin to work on EE2x please can anyone guide me in the right direction of what i need to do??.
I would be very thankful of some help.
allgood2's avatar
allgood2
13 years ago
allgood2's avatar allgood2
Is the plugin something you designed and developed? If not and you’re not familiar with EE Add-On development, you’d possibly be better off just looking for a replacement plugin. What is the plugin?
Triad's avatar
Triad
13 years ago
It is a plugin which a developer here has created
allgood2's avatar
allgood2
13 years ago
If you provide the name of the plugin, then I can tell you if there is a replacement. If you just keep calling it plugin, I can’t be helpful. I spend more time supporting people on ExpressionEngine StackExchange than here. So keep my attention while you have it. Provide full details.
I do apologize that that’s a little snippy, but your question needs details, not reiteration. If you actually provided the details that are important, such as:
I’m using plugin (plugin name: html_strip, or word limiter) by so and so and there doesn’t seem to be a version for EE2. Can it be modified, is there an alternative, or what can I do to make it EE2 compatible.
I can try to get you an answer before I leave the forums for today, which is in the next 15 minutes.
