ID Collision Between Module and Accessory
Warble Media's avatar
Warble Media
13 years ago
Warble Media's avatar Warble Media
I am working on a fairly advanced add-on that has both a module and an accessory. The module adds fields to the publish/edit page. When someone is viewing the publish/edit page and tries to open the accessory, the publish fields appear (regardless of which tab the user is currently on) and the accessory doesn’t open.
A quick look showed that the javascript that opens the accessory does so by hooking onto a html ID. The inherent issue is that when the custom fields added by the module are outputted, they are wrapped in a div tag using the same ID. This collision causes clicking the accessory to hook onto the wrong DOM node.
Furthermore, the ID for the accessory is set by the
$id
property defined in
acc.add_on_name.php
Initially I had this property set to the add-on name
add_on_name
Changing this to anything else was causing a blank screen to be displayed.
Thinking I could just change the ID on the custom fields instead, I changed the key in the array passed to
$this->EE->layout->add_layout_tabs
changing
$this->EE->layout->add_layout_tabs(array('add_on_name' => ...)))
to
$this->EE->layout->add_layout_tabs(array('add_on_name_fields' => ...))))
However, this didn’t solve the problem; the ID on the div wrapping the fields didn’t change.
I dug deeper into the EE core code and found that the ID on this wrapping field is coming from the name of the module
add_on_name from
mod.add_on_name.php
Is there something I missed? Is there a way to change either of these IDs so the accessory acts as expected on the publish page?
Warble Media
13 years ago
Anyone have any ideas on this?
Dan Decker's avatar
Dan Decker
13 years ago
Dan Decker's avatar Dan Decker
Hi Jeremy,
Thanks for posing here on the forums!
Have you looked over in the Development and Programming forum? That’s the place best suited for questions like this.
We just aren’t set up to offer direct support for add-on development. I do apologize.
