Adding custom error message to Safecracker using hook
bryantAXS's avatar
bryantAXS
13 years ago
bryantAXS's avatar bryantAXS
Hey all,
I’m doing some validation of data inside the Safecracker “entry_submission_end” hook and I’m wondering if there is a way to add a custom global error to Safecracker, after the page reloads?
I’m sure there is a way of doing it, I just don’t want to spend a few hours digging through the safecracker_lib file.
Bryant
Rob Sanchez's avatar
Rob Sanchez
13 years ago
Rob Sanchez's avatar Rob Sanchez
You should be able to do something like this:
if (isset($this->EE->safecracker))
    $this->EE->safecracker->errors[] = 'Some global error';
    //or
    $this->EE->safecracker->field_errors['title'] = 'Title must start with Z!'
bryantAXS's avatar
bryantAXS
13 years ago
Great, thanks Rob!
bryantAXS's avatar
bryantAXS
13 years ago
Rob, is there any tag or way to know if Safecracker submitted successfully? I can’t use {error_count} == 0 because when a page initially loads, it will always come back as zero… any recommendations?
