generating content using codeigniter instead of EE tags
petattlebaum's avatar
petattlebaum
13 years ago
petattlebaum's avatar petattlebaum
Hello,
I know the answer for my issue is RTFM. I’m just looking for a starting point.
I have some content (catalog-like data) where I believe the best way to call the data is using loops as opposed to EE tags.
I have already successfully used codeigniter code for email templates. But I’m stumped on how to use ci for ee templates. I know/hope I’m missing something really simple. Do I need more that the library and helper lines below to get started?
I’ve tried combining echo code along with ci ee $query = $this->db->query(“…”) but have gotten errors. Surprise, I know.
Any documentation links would be appreciated too.
$this->EE->load->library('session');
 * Load the Text Helper
$this->EE->load->helper('text');
Peter T
Bjørn Børresen's avatar
Bjørn Børresen
13 years ago
Bjørn Børresen's avatar Bjørn Børresen
Hi Peter,
I’d create an addon instead of PHP code directly in the template. Also, in general, you need to use $this->EE to access the global CI object, so your db query above should be $this->EE->db->query();
You can use http://pkg.io to generate a skeleton of your module. Just select “Module” on that page and then edit mod.yourmodule.php to include the functions you need. Functions in that file = EE tags that can be used in your templates.
Introductions to addon development can be found here: http://ellislab.com/expressionengine/user-guide/development/module_tutorial.html
.. and someone recently launched this website which seems like a good starting point: http://ee-recipes.com/
Good luck!
