Passing tags into add-on
Dan Storm's avatar
Dan Storm
13 years ago
Dan Storm's avatar Dan Storm
Hi!
I’m having some trouble passing some data from a tag into my plugin/module add-on.
Basically, I’m trying to do something like this:
{exp:imgaddon:size src="{cat_image}" size="400"}
Echoing the paramater through
$this->EE->TMPL->fetch_param('src');
returns the string “{cat_image}” instead of what the tag contains when outputted in the template.
How can I get that value?
Ralph's avatar
Ralph
13 years ago
Ralph's avatar Ralph
You could add parse=”inward” to the tag that surrounds your plugin. That will parse the outer tag before the inner one then. If that doesn’t work can you post the code that includes the outer tag?
Dan Storm's avatar
Dan Storm
13 years ago
That worked like a charm - I thought I already tried it, but I must have done something wrong then.
Thank you.
