2.5 Monday release
Developer Preview
Brian Litzinger's avatar
Brian Litzinger
about 14 years ago
I just upgraded my 2.5 install and more things are broken then before. I can’t open any jQuery dialogs. The Source button does not work (the entry actually submits), the RTE Image button doesn’t work (same dialog issue).
When I hit return to start a new line of text I get the following error: Uncaught TypeError: Object #<Object> has no method ‘is’, which is in this area of code:
query: function(){
    return this.is('unorderedList');
Uncaught TypeError: Object #<Object> has no method 'is' (repeated 7 times)
Also get this error: https://skitch.com/litzinger/8ij3g/edit-entry-expressionengine
Wes Baker's avatar
Wes Baker
about 14 years ago
Wes Baker's avatar Wes Baker
Brian,
I forgot to compress the javascript, are you using the compressed or uncompressed javascript? Could you try using uncompressed?
Wes
Brian Litzinger
about 14 years ago
Most of the errors are cleared up, but I still get one when clicking the image button:
file_manager_obj.dialog("open");
Uncaught TypeError: Cannot call method 'dialog' of undefined (repeated 2 times)
   trigger_callback = function(file) {
    callback.call(that, file, field_name);
Wes Baker's avatar
Wes Baker
about 14 years ago
Brian, I tried using the compressed and uncompressed javascript and didn’t have any issues. It sounds like jQuery UI isn’t getting loaded for some reason. Check to see if the files exist at themes/javascript/src(or compressed)/jquery/ui/.
Wes
Robzor's avatar
Robzor
about 14 years ago
Robzor's avatar Robzor
I also can confirm I got the same errors, source button submitting etc.
Wes Baker's avatar
Wes Baker
about 14 years ago
Rob,
Could you re-download and replace the whole /themes/javascript folder and let me know if you’re still getting issues?
Wes
Robzor's avatar
Robzor
about 14 years ago
Yup, that’s fixed it for me.
