New 2.5.0 Build (20120410)
Developer Preview
Wes Baker's avatar
Wes Baker
14 years ago
Wes Baker's avatar Wes Baker
I’ve just uploaded the first build of EE 2.5.0 to key lime. Here’s the changelog:
Important:
  • Improved XSS filtering of input data to prevent an XSS vulnerability.
  • Improved redirect function to prevent a CRLF injection attack.
General Changes:
  • Rich Text Editor <cp/admin/rich_text_editor_settings.html>_
    • Added new module and fieldtype for the new rich text editor.
    • Added user preferences for rich text editor under my preferences.
    • Added preference to textareas to enable the rich text editor.
  • Altered language keys on the New Template page to be consistent with the New Template Group page in the control panel.
  • Dropdown for “Preview Layout” in publish layouts sidebar updates to the member group being viewed.
  • When editing publish layouts, the checkbox for the member group being viewed defaults to being checked.
  • Reactor: Changed “edit member group” screen to show prefs for the MSM site you are presently using.
  • Reactor: Added option to member delete confirmation page to delete all entries associated with the member being deleted
Wes Baker's avatar
Wes Baker
14 years ago
Bug Fixes:
  • Fixed a bug (#16519) where adding a pre-defined HTML formatting button could result in the button being added to the wrong member account.
  • Fixed a bug where the Browse Files button had no effect after uploading via the File Manager page.
  • Fixed a bug where the currently selected upload folder on the File Manager page was not used as the default in the Upload File dialog.
  • Fixed bugs (#16802, #17442) where package paths were not added consistently.
  • Fixed a bug (#17391) where the localization link did not show in the My Account menu in the control panel unless the member also had permission to administer members.
  • Fixed a bug (#17443) where the recipient parameter in the Tell-a-Friend tag was ignored.
  • Fixed a bug (#17523) where a PHP error could occur when a member group had permission to create new channels but no channels had been assigned to that group.
  • Fixed a bug (#17523) where a permission error could occur when a group had permission to create new channels but did not have template access.
  • Fixed a bug (#17644) where the codeblock division added to code tags could be converted to entities when allowed HTML formatting was set to none.
  • Fixed a bug (#17647) where deleting a status group did not remove a reference to that group id in the exp_channels table.
  • Fixed a bug where the per page setting in Content Edit did not stick once navigating away from the page.
  • Fixed a bug (#17365) where setting your Default HTML formatting to Convert HTML and turning Automatically turn URLS into links on would cause the auto linking not to work.
  • Fixed a bug (#17440) where Safecracker was attempting to load the file browser even though it can’t use it.
  • Fixed a bug (#17690) where SafeCracker could not use the valid_ip form validation rule.
  • Fixed a bug (#17577) where filtered comments in the control panel may appear out of order.
  • Fixed a bug in the version helper that would display PHP errors if unexpected data was returned from the server.
  • Fixed a bug (#17380) where editing entries while the comment module is disabled would show PHP errors.
  • Fixed a bug (#17375) where loading the file manager with no upload destinations set would show a PHP error.
  • Fixed a bug (#17381) where upload preferences in config.php would be overwritten when preferences were saved via the Control Panel.
  • Fixed a bug (#17390) where backspace parameter would remove pagination markup.
  • Fixed a bug (#17387) where the Simple Commerce module performed an unnecessary query.
  • Fixed a bug (#17392) where file field tags referencing files in other sites’ upload destinations may not render.
  • Fixed a bug (#17402) where template restriction redirects would redirect users to the wrong template.
  • Fixed a bug (#17400) where having third_party_path defined while running the installer will show a PHP error.
  • Fixed a bug (#17406) where the category archives tag may show PHP errors.
  • Fixed a bug (#17417) where the edit entries screen would show a PHP error when converting high ASCII text to entities.
  • Fixed a bug (#17415) where having a category URL trigger word in a URL would show a PHP error if no category URL title was present.
  • Fixed a bug (#17414) where searching the template manager for “0” would show PHP errors.
  • Fixed a bug (#17435) where search parameter in Channel module would not work if keywords used a URI segment that contained special characters.
  • Fixed a bug (#17420) where some error messages did not return an the correct status code, thus improperly handled by some reverse proxies.
  • Fixed a bug (#17453) where listing entries in an MSM site by category URL title would fail if another site used the same category URL title.
  • Fixed bugs (#17449, #17497) where updating template preferences from the template edit screen would update the template type to “undefined”.
  • Fixed a bug (#17450) where where a file field without a file would cause Warnings.
  • Fixed a bug (#17421) where the file field was running excessive queries in the channel entries loop.
  • Fixed a bug (#17500) where changing an entry’s author would not update the last_entry_date field for the authors.
  • Fixed a bug (#17510) where the file entires tag wouldn’t honor the directory_id parameter if the directory ID belonged to another site.
  • Fixed a bug (#17534) where the “Return to Filtered Entries” link was missing after saving an entry selected from a filtered edit screen.
  • Fixed a bug (#17600) where saving a channel field with an field order value of zero would show a PHP error.
  • Fixed a bug (#17601) where the {total_comments} tag would only show the correct number if pagination was enabled.
  • Fixed a bug (#17607) where deleting a member from MySQL servers in ONLY_FULL_GROUP_BY mode would show a query error.
  • Fixed a bug (#17564) where the file manager modal may not fit in smaller browser sizes.
  • Fixed a bug (#17588) where category image tags would render as blank on the front end.
  • Fixed a bug (#17462) where users in GMT-6 or earlier timezones would have their autosaved entries deleted.
  • Fixed a bug (#17454) where users could not switch sites in the control panel if cookie domains were set for each site.
  • Fixed a bug (#17609) where publish layouts may not save correctly and show a PHP error on the publish page.
  • Fixed a bug (#17411) where the table header on the template manager screen may appear improperly styled.
  • Fixed a bug (#17736) where member list initial order by and sort preferences were not honored on member list screen.
  • Fixed a bug (#17732) where thumbnail preview of file fields would fail if a protocol-agnostic URL was entered for the upload destination.
Wes Baker's avatar
Wes Baker
14 years ago
Bug Fixes (continued):
  • Fixed a bug (#17719) where control panel menus were too low in the document z-order, not giving enough flexibility to CP add-ons.
  • Fixed a bug (#17715) where year, month and day fields in channel_titles table may be incorrect depending on a number of timezone factors.
  • Fixed a bug (#16948) where cropped images may sometimes be framed by black bars.
  • Fixed a bug (#17734) where deleting a field from a publish layout may result in PHP errors on the publish screen.
  • Fixed a bug (#17695) where the version helper cached version information in a hard-coded directory instead of using the cache_path config item.
  • Fixed a bug (#17627) where submitting a publish form that fails validation may delete data in that entry’s file fields.
  • Fixed a bug (#16583) where auto-linker behavior differed from 1.x, causing links without a protocol not to be converted.
  • Reactor: Fixed a bug where 3rd party module tab fields did not have their data set after an autosave.
Wes Baker's avatar
Wes Baker
14 years ago
Developers:
  • Reactor: Added $member_ids, an array of members deleted, to the cp_members_member_delete_end hook.
  • Reactor: Re-exposed channel->pager_sql in the channel module.
  • Reactor: Added parameter to Api_channel_fields::field_edit_vars to specify which field types to present as options.
  • Added myaccount_nav_setup hook to modify My Account navigation. See documentation <development/extension_hooks/cp/myaccount/index.html>_ for more information.
  • Added email_send hook to modify emails or take over email sending completely.
