Matching Single-Entry Categories to Channel Categories
elative's avatar
elative
14 years ago
elative's avatar elative
Hi EE forums,
I’m looking for a more elegant way to accomplish the following inside of a single-entry page:
  1. Dynamically list all of the categories for the channel.
  2. Mark any categories that the entry is filed under as “selected.”
  3. Mark every other list item as “odd” (e.g. items 1, 3, 5, etc.). This is potentially a separate issue (see below).
Keep in mind that each channel entry is filed under multiple (parent-level) categories and there is no category segment to reference in the URL. I will eventually employ a plugin solution as to avoid using PHP inside the template, however, I’m looking to get some feedback on this approach first:
Code
<ul>
 <?php
  $i = 0;
  // get the classes for the category
  function get_category_classes($index, $channel_category, $indexClass = 'odd', $activeClass = 'selected')
   $classes = array();
   $output  = '';
   // is the iterator an odd number?
   if ($index % 2 == 0) array_push($classes, $indexClass);
   // does the channel category match any of the entry categories?
   $entry_categories = explode(' ', '{categories}{category_name} {/categories}');
   if (in_array($channel_category, $entry_categories)) array_push($classes, $activeClass);
   // format the output (e.g. class="odd selected" or class="odd")
   if ( ! empty($classes)) $output = ' class="'.trim(implode(' ', $classes)).'"';
   return $output;
 {exp:channel:categories channel="blog" style="linear"}
 <li<?= get_category_classes($i, '{category_name}') ?>>
  <a href="http://{path=blog}">{category_name}</a>
 </li>
 <?php $i++ ?>
 {/exp:channel:categories}
</ul>
With respect to using an iterator to mark list items as “odd”: my first inclination was to use the {switch='odd|even'} tag. Sadly, this tag does not work correctly inside {exp:channel:categories} (e.g. it will return “odd” for every item). This is a known limitation, correct?
EE Info
Version: 2.4.0
Build: 20120123
Shane Eckert's avatar
Shane Eckert
14 years ago
Shane Eckert's avatar Shane Eckert
Hey elative,
Thank you for your question.
This is an interesting question, but as it’s related to PHP programming, I am going to bump this over to Development and Programming where you will get some great feedback on how to make this work for you.
If there is anything support related I can do for you, please do let me know by opening a new thread.
Thanks again for your question.
